what clutch tranny piece am i missing?, i know im missing something |
Flat VW |
Oct 5 2005, 07:23 PM
Illegal Soapbox Derby Racecar Group: Members Posts: 1,692 Joined: 13-November 04 From: Phoenix, AZ Member No.: 3,105 |
so i was laying under the car today looking for the clutch connection to the tranny.
found it (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) i found the pully thing that the clutch cable goes around then i found where the cable should attach to and its not... (IMG:http://www.914world.com/bbs2/html/emoticons/sad.gif) so i can see the rod that comes out of the passenger of the tranny and there is a fork on the end and it has a slot cut in it. i can see that there should be some piece of metal the the clutch cable runs through and then there should be a bolt on the end im guessing. so does anyone know what the missing piece is and where i could pick one up? i have attached a picture of the fork coming out of the tranny one more thing that kinda worries me... when i pull on the lever coming out of the tranny it dosent budge should it? i made sure it was out of gear first, i dont know if that would make any difference so...is that normal? sorry the picture is such low quality its the best i could do. the rod/fork thing im talking about is pretty much in the center of the frame (IMG:http://www.geocities.com/shaggy_nine14/img_1596.jpg) -shaggy (sorry im logged on as my dad) |
bd1308 |
Oct 5 2005, 09:39 PM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
I wouldn't use locktite.....it would be a huge pain to loosen that nut when you needed to.
I would contact Engman for your pedal board....it's a lifetime replacement, made from aluminum.The usual suspects have the OE board.. You *need* one so that you don't over-extend that clutch and stretch out your clutch cable.... b |
Lo-Fi Version | Time is now: 24th September 2024 - 12:53 PM |
