SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 41,704 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
did you know that the 237 original /6 that were built in '72 had a main wiring harness that is different from any other 914?
the '72 914/6 had a main wire harness that was based on the '72 914-4 but had special adapters build in to connect to the /6 relayboard. (IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,587 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
It would not be "plug and play". What they did was use a 4 cylinder chassis in 72, complete with the wiring. They put a six motor mount, oil tank, and other bits to make the six work (Kinda like a factory conversion car). The trick piece was a small adapter harness that adapted the four cylinder wiring harness to the six cylinder relay board. Jon Lowe has (had?) a diagram of that harness. |
Lo-Fi Version | Time is now: 25th June 2024 - 12:22 AM |
