> Clutch Tube Repair, Step by Step Pictures
ThinAir
post Mar 30 2005, 10:22 PM
Best friends
This is the center tunnel from the donor car, turned upside down.
bondo
post Oct 7 2005, 04:13 PM
QUOTE (McMark @ Oct 7 2005, 02:43 PM)
Welding can something like what is pictured below. The weld on the inside of the circle can either keep the cable from going through at all, or can chaff the wire enough to shorten its life-span. Gotta be careful. Brads idea is a good one.
Better would be a piece of copper tubing smeared with mig dip. It'd be flexible enough that you could feed it down the whole length of the clutch tube and it would protect it everywhere you might be making repairs. On my V8 car I'm going to do this and I'll be welding the tube in place every few inches. It won't be going anywhere! (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif)
ThinAir914   Clutch Tube Repair   Mar 30 2005, 10:22 PM
ThinAir914   This is what the center weld point looks like. Th...   Mar 30 2005, 10:24 PM
ThinAir914   This is the firewall from the donor to show what i...   Mar 30 2005, 10:25 PM
ThinAir914   This is what our firewall looked like. We were su...   Mar 30 2005, 10:28 PM
ThinAir914   The front end of our clutch tube.   Mar 30 2005, 10:30 PM
ThinAir914   The front tube bracket reinforced.   Mar 30 2005, 10:30 PM
ThinAir914   Front tube bracket #2. The brazing that you see c...   Mar 30 2005, 10:31 PM
ThinAir914   This is the flap we cut in the front of the tunnel...   Mar 30 2005, 10:32 PM
ThinAir914   This is the rear flap, measured from the cross bra...   Mar 30 2005, 10:33 PM
ThinAir914   The front bracket as originally repaired. We just...   Mar 30 2005, 10:35 PM
ThinAir914   We cut a piece from the donor's old tunnel to ...   Mar 30 2005, 10:36 PM
ThinAir914   The center weld after it was finished. You can see...   Mar 30 2005, 10:37 PM
ThinAir914   The firewall was repaired by bending the metal bac...   Mar 30 2005, 10:39 PM
ThinAir914   The finished firewall welding.   Mar 30 2005, 10:40 PM
ThinAir914   Mike was not happy with the way the welding came o...   Mar 30 2005, 10:41 PM
ThinAir914   The engine end of our tube was bent and out of rou...   Mar 30 2005, 10:45 PM
ThinAir914   My welder at work. I can't say thanks enough ...   Mar 30 2005, 10:46 PM
ThinAir914   It was only 44F and the wind was blowing when we d...   Mar 30 2005, 10:48 PM
ThinAir914   As clutch cable tube repair jobs go, I would guess...   Mar 30 2005, 10:50 PM
mattillac   nice work!   Mar 31 2005, 12:34 AM
Jeff Bowlsby   Thanks Ernie...nice job. Kinda makes you wish the...   Mar 31 2005, 01:02 AM
Mike9142.0   The picks make my welds look good   Oct 7 2005, 12:14 PM
SirAndy     Oct 7 2005, 12:22 PM
McMark   Nice Job! As you noticed, you have to be care...   Oct 7 2005, 12:43 PM
jonwatts   I like that washer on the rear firewall. I might d...   Oct 7 2005, 12:59 PM
Spoke     Oct 7 2005, 12:59 PM
jonwatts   I think he means don't burn through and block ...   Oct 7 2005, 01:20 PM
Brad Roberts   Correct Jon. I slide a number 2 Phillips into the ...   Oct 7 2005, 03:22 PM
McMark   Welding can something like what is pictured below....   Oct 7 2005, 03:43 PM
bondo     Oct 7 2005, 04:13 PM
ThinAir914     Oct 8 2005, 11:23 AM
bd1308   i guess metal ready converts rust into a paintabl...   Oct 8 2005, 11:33 AM
SirAndy     Oct 12 2005, 07:56 PM
SirAndy     Oct 15 2005, 01:22 PM
malcolm2   Sorry.... old post, but a good one. Wanted to add...   Mar 13 2023, 01:41 PM
13 User(s) are reading this topic (13 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th April 2025 - 09:58 PM
