> Clutch Tube Repair, Step by Step Pictures
ThinAir
post Mar 30 2005, 10:22 PM
Best friends
This is the center tunnel from the donor car, turned upside down.
post Oct 8 2005, 11:38 AM
Resident German
QUOTE (ThinAir914 @ Oct 8 2005, 10:23 AM)
Will spraying it with Metal Ready really help if you don't follow up with POR-15?
absolutely!
metal ready is what does all the work, POR-15 is primarily a moisture barrier and heavy duty protective coat ...
you can most certainly use metal ready all by itself and it will permanently get rid of your surface rust and create a protective coat of sorts ...
(IMG:http://www.914world.com/bbs2/html/emoticons/cool.gif) Andy
ThinAir914   Clutch Tube Repair   Mar 30 2005, 10:22 PM
ThinAir914   This is what the center weld point looks like. Th...   Mar 30 2005, 10:24 PM
ThinAir914   This is the firewall from the donor to show what i...   Mar 30 2005, 10:25 PM
ThinAir914   This is what our firewall looked like. We were su...   Mar 30 2005, 10:28 PM
ThinAir914   The front end of our clutch tube.   Mar 30 2005, 10:30 PM
ThinAir914   The front tube bracket reinforced.   Mar 30 2005, 10:30 PM
ThinAir914   Front tube bracket #2. The brazing that you see c...   Mar 30 2005, 10:31 PM
ThinAir914   This is the flap we cut in the front of the tunnel...   Mar 30 2005, 10:32 PM
ThinAir914   This is the rear flap, measured from the cross bra...   Mar 30 2005, 10:33 PM
ThinAir914   The front bracket as originally repaired. We just...   Mar 30 2005, 10:35 PM
ThinAir914   We cut a piece from the donor's old tunnel to ...   Mar 30 2005, 10:36 PM
ThinAir914   The center weld after it was finished. You can see...   Mar 30 2005, 10:37 PM
ThinAir914   The firewall was repaired by bending the metal bac...   Mar 30 2005, 10:39 PM
ThinAir914   The finished firewall welding.   Mar 30 2005, 10:40 PM
ThinAir914   Mike was not happy with the way the welding came o...   Mar 30 2005, 10:41 PM
ThinAir914   The engine end of our tube was bent and out of rou...   Mar 30 2005, 10:45 PM
ThinAir914   My welder at work. I can't say thanks enough ...   Mar 30 2005, 10:46 PM
ThinAir914   It was only 44F and the wind was blowing when we d...   Mar 30 2005, 10:48 PM
ThinAir914   As clutch cable tube repair jobs go, I would guess...   Mar 30 2005, 10:50 PM
mattillac   nice work!   Mar 31 2005, 12:34 AM
Jeff Bowlsby   Thanks Ernie...nice job. Kinda makes you wish the...   Mar 31 2005, 01:02 AM
Mike9142.0   The picks make my welds look good   Oct 7 2005, 12:14 PM
SirAndy     Oct 7 2005, 12:22 PM
McMark   Nice Job! As you noticed, you have to be care...   Oct 7 2005, 12:43 PM
jonwatts   I like that washer on the rear firewall. I might d...   Oct 7 2005, 12:59 PM
Spoke     Oct 7 2005, 12:59 PM
jonwatts   I think he means don't burn through and block ...   Oct 7 2005, 01:20 PM
Brad Roberts   Correct Jon. I slide a number 2 Phillips into the ...   Oct 7 2005, 03:22 PM
McMark   Welding can something like what is pictured below....   Oct 7 2005, 03:43 PM
bondo     Oct 7 2005, 04:13 PM
ThinAir914     Oct 8 2005, 11:23 AM
bd1308   i guess metal ready converts rust into a paintabl...   Oct 8 2005, 11:33 AM
SirAndy     Oct 12 2005, 07:56 PM
SirAndy     Oct 15 2005, 01:22 PM
malcolm2   Sorry.... old post, but a good one. Wanted to add...   Mar 13 2023, 01:41 PM
15 User(s) are reading this topic (15 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 7th April 2025 - 10:03 PM
