carb fuel pump.... |
bd1308 |
Oct 8 2005, 11:39 AM
Sir Post-a-lot Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 |
tell me what you know about them, how often they fail, what to recommend.....
I have a facet pump in the pink whatever car..... facet is the type of pump, correct? b |
Mueller |
Oct 8 2005, 11:46 AM
that is a brand...
basicly you need a pump that'll give you the lower PSI feed that carbs need and you need one with enough volume to feed it at WOT, with our tiny motors, pretty much any automotive carb fuel pump will work...it's once you get into 500hp V8's do you need to worry about volume i'd be leary of used junkyard pumps since you don't know the history of them.....not too much to go wrong with them and some you should be able to open up and inspect and repair |
Lo-Fi Version | Time is now: 28th June 2024 - 09:19 AM |
