thomasotten |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,550 Joined: 16-November 03 From: San Antonio, Texas Member No.: 1,349 ![]() |
What do you think? Gimmick? I find the 12% figure a little hard to believe. Maybe they were just measuring inlet/outlet temperature of the filter, not OVERALL oil temperature.
(IMG:http://content.madirect.com/img300/fr2423.jpg) From the Tweeks website: Tests have revealed a 12% reduction in oil temperature thanks to the Cool Collar, a finned aluminum cooler that increases the surface area by four times, allowing it to radiate heat faster and more efficiently. Unit fits all air and water-cooled Porsche oil filters with a simple slip-on, clamp down installation. |
phantom914 |
non-914-owner non-club member ![]() ![]() ![]() Group: Benefactors Posts: 1,013 Joined: 24-February 04 From: Covina,CA(North ofWest Covina) Member No.: 1,708 ![]() ![]() |
They are trying to say that without the collar, the oil is 150 degrees above ambient(220-70) and with the collar, the oil is 132 degrees above ambient (202-70) or 18 degrees less. 18 degrees is 12% of 150. The lab test is not too real world in the sense that you will not have 50mph, 70degree air blowing across your filter. Also, the rate that their test setup put heat into the oil may not be the same as the rate that your engine puts heat into the oil. Actually, I would bet on it. They don't seem to understand the difference between heat and temperature either. Andrew |
Lo-Fi Version | Time is now: 28th June 2024 - 04:35 AM |
