door gap, how big should they be |
grasshopper |
Oct 9 2005, 06:42 PM
Advanced Member Group: Members Posts: 2,613 Joined: 10-December 04 From: Valdosta, GA Member No.: 3,258 Region Association: None |
ok, put the 914 on jack stands today, with a 2x6 underneath of each, to level the car out. I think it worked pretty well. Is the gap big enough now, to weld in a brace, before i replace the longs, or should it be bigger. I compared it to the other teener, and they look to be close to the same. Here is the before.....ignore the big hole next to it. I did some work today, that i am pretty pleased with (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
Attached image(s) |
michelko |
Oct 9 2005, 10:54 PM
Senior Member Group: Members Posts: 867 Joined: 30-November 03 From: Germany, Lambsheim Member No.: 1,404 Region Association: None |
Hi Grasshoper,
be aware that putting in some heat into the tub will make it shrink a little bit. You have to adjust a little more gap then you want after Welding. I went fine with about 3-4 mm plus with my Hell Hole restoration. Not sure if this is also the right amount for your project (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_flagge6.gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:34 PM |
