engine rotation direction, info needed |
type47 |
Oct 10 2005, 09:36 AM
Viermeister Group: Members Posts: 4,254 Joined: 7-August 03 From: Vienna, VA Member No.: 994 Region Association: MidAtlantic Region |
i want to do a preliminary valve adjustment on a long block and maybe install the distributor and want to know in which direction, clockwise or counter clockwise, does the stock 2.0L engine rotate, that is, as you look at the flywheel, would the engine turn clockwise or counter clockwise? when i installed the p&c's, i lubed everything up and also ask if rotating the crank and p&c's in the longblock will score the cylinders or score the bearings. many TIA
the engine is the one in the avatar but i am further along, just ordered a few of the last required pieces, triad should be the last (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) |
Mark Henry |
Oct 10 2005, 09:55 AM
Clockwise from the pulley end (as in your avatar) is the correct way to state its rotation direction.
Find TDC #1 adjust #1 valves, rotate 180 degress counter-clockwise adjust #2, again rotate 180 degress counter-clockwise adjust #3, rotate 180 degress counter-clockwise adjust #4 |
Lo-Fi Version | Time is now: 28th June 2024 - 09:01 AM |
