> Advice on liquidating projects, what is the best $ return?
nine14cats
post Oct 9 2005, 11:00 PM
Bill Pickering -- 914-6 GT aka....Leeloo
I'm thinking of cleaning up my garage a tad. I've got several projects and some rental home rennovations going and it's just too busy. I've decided I will be on the track as soon as possible (whatever that means), so I have several options on what I can do.
I have a car currently being built (The BEAST). I also have a pretty V8 donor car (JLO). I've got spare 914 / 911 parts up the wahzoo.... (IMG:http://www.914world.com/bbs2/html/emoticons/laugh.gif)
I may continue with the "BEAST" build. I may pull the plug. I can get into an existing race car for about the same money as my current project, although The BEAST is new from ground up. I won't get that.
My question is: Is it our collective opinion that I would make more money back assembling finished cars and selling? Or parting out? I have the race car, I have JLO with EVERY part needed to finish it's V8 Renegade conversion in my garage. I have a 3.6 993 motor and full blown WEVO flipped tranny with every imaginable upgrade. I could make JLO a V8 or I could put the 3.6 in her. I could finish the race car (seems like bad return on money versus selling the parts).
What do you folks think would be the best way to recoup "some" of my money and get back to racing? This will help me with my cost analysis to help me think through my options. You get to help me with my homework.
Parts / Cars list:
Let's start with "The BEAST"
914 chassis.
Suspension points raised 2 inches in the body.
Full cage.
Fuel Cell.
Adjustable Sway bars. (SMART bar Front)
2 way adjustable shocks (Advanced Design).
Coil over fronts
JZR 4 pot racing brakes
Sheridan Body Kit
Roller Bearing suspension
Body work and chassis can be painted and car partially assembled.
Motor: 1995 993 3.6 with stock ECU. Has Patrick Motorsports coated 1 3/4 inch headers with O2. Motor has been dyno'd. All PMS clutch, DME, etc installed on motor.
Trans: Flipped 915 transmission fully rebuilt with new bearings, synchros, etc. WEVO 914 conversion end cover. WEVO gateshift internal. New bearing retainer assembly. New Paul Guard 80% LSD. Trans has been machined for external oil cooler.
WEVO reduced throw shift
Tires:
(4) 22x10x16 Hoosier R45 Bias Ply slicks (NEW)
(4) 23.5x11.5x16 Hoosier R45 Bias Ply slicks (NEW)
(2) 23.5x10.5x16 Goodyear R600 Bias Ply slicks (NEW)
(2) 25x13x16 Goodyear R600 Bias Ply slicks (NEW)
Wheels:
(4) HRE mesh 16x10 5 5/8 inch offset racing rims
(4) Diamond Racing 16x10 5.25 inch offset racing rims (NEW)
(2) Diamond Racing 16x12 5.25 inch offset racing rims (NEW)
Now let's look at JLO:
1975 914 finished car with STEEL GT extra wide flares. No rust. Everything there minus engine and trans. Yellow. 17x8 front rims and 17x9.5 rears (Borbet).
Motor and trans in my garage:
350 SBC V8. Demon 4bbl carb. HEI. Edelbrock Performer Alum heads and Intake manifold. Comp Cam. RH headers. Flowmaster 40's. Dyno'd at 380HP and 300 ft/lbs torque. Not a beater engine. Fully rebuilt to Renegade Hybrid (RH) specs (Wild Bill).
The engine has the RH serpentine system assembled on it with A/C compressor.
Tranny is a rebuilt tall gear ratio 4 speed 901 from RH. It is currently mated to the SBC utilizing RH conversion gear. I have all RH conversion parts including radiator / fan system, underdash heat and A/C system, RH engine cradle, tranny mounts, complete wiring harness installed on motor, etc....
I've got more goodies I could list, but you get the picture.
What are the opinions of the collective? Decision timing for me is to figure this out in the next 2 to 4 weeks.
Thanks,
Bill P.
nebreitling
post Oct 10 2005, 12:04 PM
Member Emeritus
QUOTE (ppickerell @ Oct 10 2005, 08:46 AM)
Two words for you Bill, SPEC BOXSTER!
and KA-BOOM goes another boxster engine.... have they solved the oiling problems on 'em yet? (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
part out JLO, finish the BEAST. it's a no brainer. even if you don't have too much track time in the future, you'll have a finished, beyond-capable car.
nine14cats   Advice on liquidating projects   Oct 9 2005, 11:00 PM
jonwatts   Since it sounds like everything you own is in piec...   Oct 9 2005, 11:10 PM
SirAndy   http://www.914world.com/bbs2/htm...   Oct 9 2005, 11:15 PM
lapuwali   <...   Oct 9 2005, 11:22 PM
Dan (Almaden Valley)   so the beast build is getting to you Bill? Sorry t...   Oct 9 2005, 11:28 PM
McMark   <...   Oct 9 2005, 11:29 PM
J P Stein   I agree that the parts will bring you more money m...   Oct 9 2005, 11:45 PM
nine14cats   Thanks for the response guys. I really mean it. ...   Oct 10 2005, 12:05 AM
GWN7   The end result is that you want to race. So sellin...   Oct 10 2005, 12:06 AM
McMark   You can step down, but you can't step up. Mea...   Oct 10 2005, 12:21 AM
nine14cats   Hi Mark, I think The Beast will be too much car f...   Oct 10 2005, 12:31 AM
rhodyguy   or just put the 4 back in jlo and drive the damn t...   Oct 10 2005, 07:34 AM
lapuwali   ...   Oct 10 2005, 09:00 AM
Mueller   I'd sell the V8 stuff.... Install the 3.6 int...   Oct 10 2005, 09:11 AM
Verruckt   <...   Oct 10 2005, 10:07 AM
Rotten Robby   <...   Oct 10 2005, 10:24 AM
ppickerell   Two words for you Bill, SPEC BOXSTER!   Oct 10 2005, 10:46 AM
nebreitling     Oct 10 2005, 10:33 PM
Dan (Almaden Valley)   Bill, I know some information about the boxster th...   Oct 10 2005, 10:36 PM
jonwatts   He replaced the engine with another 2.5? <...   Oct 11 2005, 11:30 AM
jonwatts   <...   Oct 11 2005, 12:01 PM
nine14cats   Hi Gwen, The spec series for Boxster's is a p...   Oct 11 2005, 12:57 PM
GTeener   http://www.914world.com/bbs...   Oct 11 2005, 04:27 PM
0396   Bill, Sorry to hear of your concerns. If your go...   Oct 12 2005, 06:26 AM
trekkor   I guess today's the day h...   Oct 12 2005, 09:48 AM
ppickerell   Spec Boxster is going to work for a lot of Husband...   Oct 12 2005, 07:20 PM
Twystd1   Two things... I know where a 1997 boxtser is .. C...   Oct 12 2005, 07:33 PM
ppickerell   Cheap would be $10,000. I have seen 97's ...   Oct 12 2005, 08:13 PM
Twystd1   I do believe it is about 10 Gs.. If ya want me to...   Oct 12 2005, 08:29 PM
nine14cats   I had a great, productive meeting with the shop to...   Oct 13 2005, 01:12 AM
nine14cats   Option #2 2000 996 -- Water Pumper! Believe ...   Oct 13 2005, 01:18 AM
nine14cats   Option #3....The BEAST On paper this thing should...   Oct 13 2005, 01:25 AM
nine14cats   So I have choices to think over. And thanks to ou...   Oct 13 2005, 01:32 AM
McMark   Aren't decisions wonderful? ...   Oct 13 2005, 07:33 AM
trekkor   Bill, stand tall and sing along! Beast, Beast...   Oct 13 2005, 09:55 AM
7 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
- Lo-Fi Version Time is now: 21st December 2024 - 11:14 PM
