bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
is it 27 or 35 or some number in the middle?
i've seen 35 before..... FI mark is 27 or 28degrees..... which is it...help please. b |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 15,000 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
The Pelican article, as I recall, talked about either 30 degrees or 32--not 35. It was also using an aftermarket distributor. Since you're using the stock distributor, set the timing the stock way-- 27 deg BTDC at 3500 RPM with the vacuum hoses (if any) disconnected and plugged.
--DD |
Lo-Fi Version | Time is now: 26th June 2024 - 01:27 AM |
