Wiring question |
Wiring question |
dennisc |
Oct 14 2005, 02:34 PM
Member Group: Members Posts: 90 Joined: 1-September 04 From: Marshall, MO Member No.: 2,671 |
My dash brake light does not work so I have done some looking around. The wiring diagram at the master cylinder shows two wires. Brown and white and a brown ground wire. I have both at the master cylinder but only the brown and white was connected. There is only one spade connection on the switch. How should this we wired?
ClayPerrine |
Oct 14 2005, 02:39 PM
Life's been good to me so far..... Group: Admin Posts: 15,969 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
The brown wire is a ground for the switch. The later replacement master cylinders ground their switch through the body of the master cylinder. You only need to hook up the brown/white wire. The other can be left loose.
To see if the light is working, just hook the two wires together. The light in the dash should flash. |
Lo-Fi Version | Time is now: 6th January 2025 - 07:31 PM |
