Wiring question |
Wiring question |
dennisc |
Oct 14 2005, 02:34 PM
Member Group: Members Posts: 90 Joined: 1-September 04 From: Marshall, MO Member No.: 2,671 |
My dash brake light does not work so I have done some looking around. The wiring diagram at the master cylinder shows two wires. Brown and white and a brown ground wire. I have both at the master cylinder but only the brown and white was connected. There is only one spade connection on the switch. How should this we wired?
lapuwali |
Oct 14 2005, 02:44 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Brown/white wire should go from the switch to the dash brake light. The brown wire is a ground for something else. The light should also come on with the handbrake is pulled up. If not, then check the bulb. There's also a black/white power wire that leads to it.
Lo-Fi Version | Time is now: 6th January 2025 - 07:10 PM |
