Brotherbob |
Lazy Hack ![]() ![]() Group: Members Posts: 152 Joined: 6-September 05 From: Granbury TX Member No.: 4,756 ![]() |
edit 1.8 L Oil cooling AGAIN!
Maybe one of the Gurus can help? Where the hell do all the hoses go ? Sump has 2 ports. Oil cooler block has two ports. When I put the cooler in the front bumper it has two ports. So which hose goes where? Help a brother out. Hold on for a few pics. (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) Attached image(s) ![]() |
Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
here is my suggestion.
run a stock cooler. (solves problem number 1) run a MOCAL sandwhich plate (lets you USE stock oil filter AND has a thermostat that control oil flow to front cooler) either run drains from heads to deep sump.... or cap it off. BTW, with your current set up - there is NO OIL FILTER unless you plumbed one upfront. |
Lo-Fi Version | Time is now: 28th June 2024 - 10:39 PM |
