WHO |
Newbie ![]() Group: Members Posts: 12 Joined: 13-May 04 From: Denver, Colorado Member No.: 2,065 ![]() |
I'm in Coloredo and drive from 5000 to 12000 ft elevation. I'm rebuilding my 1.7 this winter to a 2.0 and want to bump up the compression ratio to 9 or 9.5 :1 to make up for the altitude. Will an added oil cooler keep me from overheating? I've heard the 911 type fans and fiberglass shroud will not fit. Is that true?
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Cooling the oil won't cool the heads...
Head and oil temps are totally separate entitiesand are impacted by many different things from RPM (oil temp) to load (head temp)... Your stock cooling system is more than likely adequate and will probably perform better than the 911 systems. I have tested 911 systems comprehensively compared them all off the shelf and lemme tell ya that no one has done any development with them. I did this testing to see and prove just how good my DTM cooling system was and I was amazed. At your altitude the higher CR may make the engine run cooler through better efficiency. When I build engines to operate constantly at altitude I run more CR with the combo to make up for the less dense air. Doing so typically ups efficiency and incread efficiency makes for cooler running. For you the key component is the camshaft undoubtedly- The stock cam is horrible, especially at altitude. "Its all in the combo" meaning you have total control of the outcome, make wise decisions and do your homework. If it does run too hot, here is your answer. Its scheduled for a Christmas release date and has been in testing here for over a solid year. 914 DTM |
Lo-Fi Version | Time is now: 26th June 2024 - 07:43 AM |
