> I'm depressed, 2 hours of dyno time for nut'n....., Ignition cr@pped out, wouldn't restart:(
Mueller
post Nov 1 2005, 06:12 PM
914 Freak!
What a waste of a day off.... (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif)
I knew it was going to be one of those days when my laptop wouldn't communicate with the Link ECU, luckly I brought a back up unit that I normally use, it's just that the 1st laptop I had was way, way faster...(normally)
Mark D (McMark) showed up and helped stomp on the gas while I played with the laptop, we started @ 1000rpm and went up in 500rpm increments...strange feeling with the pedal @ WOT in 4th gear and the motor would not go over the set load...
I kept hearing a misfire and then all of a sudden under load it got real bad, we changed out the distributor cap since the original one had some viewing holes cut into it for timing....it just got worse...then I noticed the air intake elbow was a little loose so I fixed that...I was hopeing that was it...nope still really bad misfires coming out of the exhaust....finally I load a new MAP setting and the car seemed to be idling better, then all of a sudden the car dies..."hey Mark, did you turn it off???"
"nope"
"oh $hit"
I get out the voltmeter, I have voltage like I should, no apperant spark....
So, it's one of the following I think (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
a bad MSD box, a bad optical sensor in the dizzy or the Link is messed up....I have a check list of items to go over before sending the Link back for testing....
I think i want to replace the optical sensor within the dizzy with a hall effect unit, any leads or ideas?
McMark dyno's his car, I'll let him tell you about it...he had better luck than me
airsix
post Nov 3 2005, 02:23 PM
I have bees in my epiglotis
QUOTE (lapuwali @ Nov 3 2005, 11:50 AM)
The Link may use a "next cylinder" method, which is similar to what some GM systems do, and MS has a mode for it. The pulse arrives X degrees before cylinder C, but the ignition is calculating the advance for cylinder C+1. So, the pulse is really 90 + X crank degrees before the plug that's actually being fired, on a four-cylinder engine.
That's cool. I like it. Thanks for explaining.
-Ben M.
Mueller   I'm depressed, 2 hours of dyno time for nut'n.....   Nov 1 2005, 06:12 PM
Dr. Roger   Dang Mike, very sorry to gear that BS happening. ...   Nov 1 2005, 06:28 PM
lapuwali   Couldn't make it today, sorry. Way too much w...   Nov 1 2005, 06:29 PM
McMark   Yeah, it was a major bummer for Mike. We started ...   Nov 1 2005, 06:51 PM
bug man nrg   Some time's this isnot what we need but it is ...   Nov 1 2005, 07:13 PM
fiid   bizarrely enough - I could really use some dyno ti...   Nov 1 2005, 07:20 PM
Mueller   we have a "runner"......problem fixed...sorta... ...   Nov 1 2005, 07:50 PM
Jake Raby   That rotor being so wide can definately add some w...   Nov 1 2005, 08:41 PM
McMark   That sucks. I wonder why there was a problem.   Nov 1 2005, 08:44 PM
Mueller     Nov 2 2005, 12:08 AM
Porcharu   Sorry to hear about your "issues" at dyno time - m...   Nov 2 2005, 12:34 AM
bd1308   what causes the MSD boxes to die? b   Nov 2 2005, 01:32 AM
Mueller     Nov 2 2005, 07:41 AM
DNHunt   Man, I swear the only luck you have is bad luck. Y...   Nov 3 2005, 08:22 AM
Mueller   Yea, bad luck tends to kick me in the @ss once in ...   Nov 3 2005, 09:02 AM
lapuwali   This part is discussed endlessly on the MSEFI foru...   Nov 3 2005, 09:23 AM
fiid   Yeah - I think the MSv3 board can run a set of tho...   Nov 3 2005, 10:40 AM
airsix   Mike, You had the link firing the coil before? I t...   Nov 3 2005, 11:11 AM
Aaron Cox   IIRC mike has a Mallory Unilite (optical pickup) a...   Nov 3 2005, 11:13 AM
jonwatts   ...   Nov 3 2005, 11:34 AM
Mueller     Nov 3 2005, 11:39 AM
lapuwali   You're going to pull the Unilite and fit your ...   Nov 3 2005, 12:16 PM
airsix   Okay, that makes sense. Sounds good. I'm curri...   Nov 3 2005, 12:25 PM
Aaron Cox   <...   Nov 3 2005, 01:08 PM
lapuwali   The Link may use a "next cylinder" method, which i...   Nov 3 2005, 01:50 PM
airsix   <...   Nov 3 2005, 02:23 PM
Mueller   <...   Nov 3 2005, 03:19 PM
fiid   You can make the v2 megasquirt do everything that ...   Nov 3 2005, 05:45 PM
Mueller     Nov 3 2005, 06:00 PM
Mueller   hmmmm...I just got an e-mail from Link, I asked fo...   Nov 3 2005, 06:18 PM
Aaron Cox   mike - hijack... how do you TIME a MSD style igint...   Nov 3 2005, 06:19 PM
Mueller   ...   Nov 3 2005, 06:27 PM
Aaron Cox     Nov 3 2005, 06:28 PM
lapuwali   Multi-spark boxes usually confuse adjustable timin...   Nov 3 2005, 07:21 PM
Aaron Cox   rock on james.... so, an adjustable one set at ma...   Nov 3 2005, 08:57 PM
McMark   It would work only if your particular CDI/MSD box ...   Nov 3 2005, 09:07 PM
TimT
  Nov 3 2005, 09:48 PM
- Lo-Fi Version Time is now: 26th June 2024 - 07:29 AM
