914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,921 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I was looking thru the 914-6 competion parts manual to check on vented rear caliper rotors insead of using spacers on hub or washers on the caliper. The part number for those is 901.352.041.12. So I called Porsche and they said they were available from Germany at $275 each.
Does anybody have a cross refference to Zimmerman rotors? So I could see if they are available at a much lower price? 901.352.041.14 is the standard 911 rear vented rotor from 69-on so I am guessing that the .12 makes these special. Any comments? Thanks, Mark. |
Mueller |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 17,146 Joined: 4-January 03 From: Antioch, CA Member No.: 87 Region Association: None ![]() ![]() |
so what caliper are you going to use? I thought the stock /6 rear is solid...so a spacer or something non-stock sounds like it'll have to be used??? |
Lo-Fi Version | Time is now: 26th June 2024 - 08:56 AM |
