914Sixer |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,921 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region ![]() ![]() |
I was looking thru the 914-6 competion parts manual to check on vented rear caliper rotors insead of using spacers on hub or washers on the caliper. The part number for those is 901.352.041.12. So I called Porsche and they said they were available from Germany at $275 each.
Does anybody have a cross refference to Zimmerman rotors? So I could see if they are available at a much lower price? 901.352.041.14 is the standard 911 rear vented rotor from 69-on so I am guessing that the .12 makes these special. Any comments? Thanks, Mark. |
davep |
914 Historian ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,162 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada ![]() ![]() |
The 914/6 GT used regular 914/6 rear calipers that were spaced 10mm. The same spacers as are used in the common 911 rear brake caliper; the two calipers are the same bore and share the outer casting. The rotor used was a variation on the 911 vented rear rotor that used a different offset to center the rotor in the caliper without spacers. It may also be slightly smaller in diameter, as is the solid 914/6 rotor. So it was a simple solution: widen the caliper with the available spacers, and a custom rotor to suit. The front was even more simple: existing rotor with a custom caliper (borrowed from the 908) the bore was slightly bigger, and the pads slightly thicker. A 20mm master cylinder was commonly used, borrowed from the 911S, but some people adapted the 23mm master. |
Lo-Fi Version | Time is now: 26th June 2024 - 08:45 AM |
