ChicagoChris |
It was jack-stand-tastic! ![]() ![]() Group: Members Posts: 168 Joined: 3-November 05 From: Chicago (burbs), IL Member No.: 5,062 ![]() |
Where do I begin? So much talk about brakes and I am nocloser to a solution. I went with the 2002tii brakes from 1972 on limited information and got burned. The posting says they are a bolt-on to the early 914's so I tried them. No good. The bolt spacing on them is almost a 1/2 inch different. Did I get the wrong year? And does someone have the dimentions from the BMW 320i rotors so I can order a custom vented hat/rotor for my 1972 914 2.0? (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif)
1973914 |
Member ![]() ![]() Group: Members Posts: 353 Joined: 16-May 03 From: Washington, DC Member No.: 703 ![]() |
Chris - are you staying 4 lug or going to 5? If going to 5 there are some very fine options for braking (the best reason to go to 5 lug).
I am using carrera rotors all around with Boxster fronts and carrera rear calipers, with a 19mm MC and no prop valve. Brake fade is not a problem (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) |
Lo-Fi Version | Time is now: 1st July 2024 - 04:39 AM |
