GT style oil line routing, Here's what I did |
michel richard |
Nov 5 2005, 07:19 PM
Senior Member Group: Members Posts: 1,291 Joined: 22-July 03 From: Longueuil, Québec Member No.: 936 |
As part of my /6 restoration, I decide that if I run a front cooler, I'd like to run the lines to it GT style.
Here's the main retoration link: http://www.914world.com/bbs2/index.php?act=...f=2&t=34896&hl= I showed in a previous thread how I began to cut off the supports on the drive side outer longitudinal: http://www.914world.com/bbs2/index.php?act=...f=2&t=40719&hl= Here's the followup. I cutoff the front-most support entirely. Please note my mistake: this support does not extend all the way to the outer longitudinal. A chunk of the cut that I made was into steel that will remain: Attached image(s) |
michel richard |
Nov 5 2005, 07:32 PM
OK, so the picture may be a bit too much of a close up. I'll try and take another one tomorrow, to show where this hole is.
This part of the work was a little more nerve wracking, because I started with a bit of a mistake, and because it's a little bit harder to figure out where to put the holes. Finally, I made a shut-piece for the hole on the outer long. I will obviously have to customize this when I put the oil lines in. Attached image(s) |
Lo-Fi Version | Time is now: 9th January 2025 - 05:43 AM |
