5dogs |
Newbie ![]() Group: Members Posts: 15 Joined: 18-September 04 From: Eureka, CA Member No.: 2,784 ![]() |
I just spent an hour digging around the problem rust areas on my 73. The only thing I found was a few pin holes on the rear floor underneath, on both sides. I pulled the battery and dug down in the Hell Hole. It all looks good. Rockers, fire wall, are solid. Sooo, my question is this; How much sag is normal, if any?? I noticed my windows hang up slightly on the rubbers seal when car is on the ground but when I jack up the car using the jack points, the windows don't drag. Do I have a problem or do I need to adjust the windows someow?? If I do have a problem, will the Stiffening Kit help?? (Engman, I think!) Thanks again.
jet1 |
Member ![]() ![]() Group: Members Posts: 311 Joined: 16-June 04 From: Accord,NY Member No.: 2,213 Region Association: North East States ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/agree.gif) the best way to tell if you have a problem is to
look at the door gap. The windows may just be out of line. Have you removed the rocker panels? The jack points and the longs are where you should look next for rust. If you do have a problem the stiffening kits are not a quick fix. you should fix the rust areas first, then add a stiffening kit if you still need it. |
Lo-Fi Version | Time is now: 22nd June 2024 - 07:40 PM |
