oil oil everywhere 74 914/4 2.0, drips on exhaust and smokes |
lbreen |
Nov 6 2005, 02:02 PM
Newbie Group: Members Posts: 29 Joined: 15-November 04 From: chicago Member No.: 3,119 Region Association: None |
Got this oil leak that drips on the exhaust and does smoke. I have the valve cover gaskets, and wonder if the pushrod tubes are hard to change or fix? This could be the problem also. I 'm wonder about the tubes because the oil leak seems to be getting worse. Thanks for you ideas. Larry .....
bottomend |
Nov 6 2005, 09:57 PM
Member Group: Members Posts: 180 Joined: 27-August 05 From: LA,Ca Member No.: 4,683 |
I've got a case opened up here on my bench and the studs for the thermo dont go all the way through. I can see the cast indentation for the stud(s) inside the case below the flange that the windge tray attaches.
did different case's have different holes? |
Lo-Fi Version | Time is now: 25th June 2024 - 04:43 PM |
