TonyAKAVW |
That's my ride. ![]() ![]() ![]() ![]() Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None ![]() |
So I've been thinking about different ways to get air up to the radiator in the subaru conversion where the radiator is in the engine bay. The standard way to do it is to have a couple of normal radiator fans sucking air from beneath the car.
Here's another idea... What if I constructed an array of ducted fans as in the diagram below. Basically they would force air up the shroud and through the radiator. One advantage to this is that it would take advantage of the entire surface of the radiator, rather than a round section that a fan would push through. Something I'm trying to figure out is the conversion between thrust and CFM of air moved. Most of these fans are for hobby RC airplanes and are rated in ounces of thrust, rather than moved volume of air. -Tony Attached image(s) ![]() |
SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Add a couple more and you could have a 2J Sucker Car (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif)
Lo-Fi Version | Time is now: 26th June 2024 - 12:22 AM |
