Another silly idea, ducted fans for a radiator! |
TonyAKAVW |
Nov 10 2005, 05:36 PM
That's my ride. Group: Members Posts: 2,151 Joined: 17-January 03 From: Redondo Beach, CA Member No.: 166 Region Association: None |
So I've been thinking about different ways to get air up to the radiator in the subaru conversion where the radiator is in the engine bay. The standard way to do it is to have a couple of normal radiator fans sucking air from beneath the car.
Here's another idea... What if I constructed an array of ducted fans as in the diagram below. Basically they would force air up the shroud and through the radiator. One advantage to this is that it would take advantage of the entire surface of the radiator, rather than a round section that a fan would push through. Something I'm trying to figure out is the conversion between thrust and CFM of air moved. Most of these fans are for hobby RC airplanes and are rated in ounces of thrust, rather than moved volume of air. -Tony Attached image(s) |
Rand |
Nov 10 2005, 06:24 PM
Cross Member Group: Members Posts: 7,409 Joined: 8-February 05 From: OR Member No.: 3,573 Region Association: None |
The expanded metal grill in the engine lid is the air INTAKE on a stock 914, is it not? The impeller is above the engine seal, so it sucks cool air from above, right?
Lo-Fi Version | Time is now: 26th June 2024 - 12:17 AM |
