front brake stuff, struts/rotors/calipers |
dmenche914 |
Nov 13 2005, 12:07 AM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Got some questions on front brakes. The catalogs list both thru 1972 and post 1972 parts for rotors, pads, calipers and the ball joint. I assume the spindle forging is also different at the 72/73 change. Is this true?
Can later calipers be put on an early car and if so, what needs to be changed? i have an early car, and found the brake calipers i want to use do not fit, they rub on the rotor. The calipers are from a1974 car. What can be done with mix and match front brakes? I also have some adjustable front shocks, can they be installed on my early spindle? (they are currently on a late spindle) Are the adjustable front shocks a huge advantage over the non-adjustable? thanks |
Eric_Shea |
Nov 13 2005, 05:01 PM
PMB Performance Group: Admin Posts: 19,279 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains |
Boy... I REALLY don't want to get into a brazing vs. welding thing again but, that would be very odd indeed. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) The offset is clearly different. (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif) Attached image(s) |
Lo-Fi Version | Time is now: 19th June 2024 - 01:32 PM |
