front brake stuff, struts/rotors/calipers |
dmenche914 |
Nov 13 2005, 12:07 AM
Senior Member Group: Members Posts: 1,212 Joined: 27-February 03 From: California Member No.: 366 |
Got some questions on front brakes. The catalogs list both thru 1972 and post 1972 parts for rotors, pads, calipers and the ball joint. I assume the spindle forging is also different at the 72/73 change. Is this true?
Can later calipers be put on an early car and if so, what needs to be changed? i have an early car, and found the brake calipers i want to use do not fit, they rub on the rotor. The calipers are from a1974 car. What can be done with mix and match front brakes? I also have some adjustable front shocks, can they be installed on my early spindle? (they are currently on a late spindle) Are the adjustable front shocks a huge advantage over the non-adjustable? thanks |
davep |
Nov 13 2005, 05:04 PM
914 Historian Group: Benefactors Posts: 5,161 Joined: 13-October 03 From: Burford, ON, N0E 1A0 Member No.: 1,244 Region Association: Canada |
The change from 72 to 73 style was to allow thicker pads to be used. This made the calipers wider. For whatever reason they decided on a whole new setup. Then they also added the centering ring on the rotor, so there were three rotor styles. One almost never sees the mid style rotor which is a good thing in one respect since it closely resembles the early style but is not interchangeable with it.
It is far better to use all the components as a set without trying to mix and match. Even the brake lines are different. |
Lo-Fi Version | Time is now: 19th June 2024 - 01:42 PM |
