BenNC |
Member ![]() ![]() Group: Members Posts: 140 Joined: 7-February 03 From: Cary, NC Member No.: 267 ![]() |
The flange for the CV boots that I bought came with 6 holes. Knowing that only 4 of these would be filled with bolts, I put a bead of gasket material to seal the grease in. This seems to have worked for one side, but the other is steadily coating the underside of my trunk with CV grease.
Any thoughts other than to clean it up and try again? Thanks |
Dave_Darling |
914 Idiot ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 14,994 Joined: 9-January 03 From: Silicon Valley / Kailua-Kona Member No.: 121 Region Association: Northern California ![]() ![]() |
Uhh, I don't think I understand what you're saying here. (IMG:style_emoticons/default/sad.gif)
There should be two roll pins holding the outer cage of the CV joint onto the transmission output flange, in addition to the four bolts. Ditto on the stub axle end. If you are specifically asking about the boots, I'm not sure what to say. --DD |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:47 PM |
