IanStott |
Member ![]() ![]() Group: Members Posts: 226 Joined: 13-June 04 From: Moncton,New Brunswick,Canada Member No.: 2,199 ![]() |
OK, I have messed up somehow, I took all the engine tin off, the fan and large fan shroud etc., had stuff powder coated and cleaned. Started putting things back on last night and the fan is not centered in it's hole, it is touching on the alternator side. What has happened?
Ian Stott Moncton |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 121,302 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
When you say "fan shroud" do you mean the big cast aluminum housing? I had this happen too. Make sure the fan is tighten down to the hub. Mine was a little off and made the fan crooked in the opening. There also maybe a little slop in how the rear section of the fan housing fits on the four studs on the front of the engine. Loosen up the nuts and move the housing around. Keep working it and it will line up. Paul |
Lo-Fi Version | Time is now: 25th June 2024 - 09:18 PM |
