IanStott |
Member ![]() ![]() Group: Members Posts: 226 Joined: 13-June 04 From: Moncton,New Brunswick,Canada Member No.: 2,199 ![]() |
OK, I have messed up somehow, I took all the engine tin off, the fan and large fan shroud etc., had stuff powder coated and cleaned. Started putting things back on last night and the fan is not centered in it's hole, it is touching on the alternator side. What has happened?
Ian Stott Moncton |
bondo |
Practicing my perpendicular parking ![]() ![]() ![]() ![]() Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California ![]() |
Is the distributor in? If the drive gear moves, it can bind with the gear on the crank and stop it from turning.
Also, without the flywheel on, the crank can move forward and back. It's possible that it's moved enough that something is hitting something it shouldn't. |
Lo-Fi Version | Time is now: 25th June 2024 - 09:29 PM |
