Maine914 |
Member ![]() ![]() Group: Members Posts: 99 Joined: 30-January 03 From: Maine Member No.: 215 ![]() |
Just got some seals from Tweeks for the trunks. The remnants of the seals on the trunks seem to have fit right on without glue. The replacements don't go right on. Is it glue time?
Any advice on putting the squeegies on the windows and the rear window seal? Thanks |
boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
The rear window seal has a metal clip inside the seal, you need to get iton and once stated it goes fairly quick. Do not glue on any of the rubber seals that go on the trunk, they also have metal clips inside and slide down over the lip on the trunk, you may need to use a hammer(soft) to get it started.
The squeeges go on after you remove the very small screws that hold the window top guide caps on, there may also be an inner screw, caereful easy to lose down the window channel. They slide in rather easily after you lube them , soap , silicone spray,WD40, whatever works for you. CCLINSEALLAND |
Lo-Fi Version | Time is now: 4th July 2024 - 01:35 PM |
