Wiring hell, stumped-long. |
Hammy |
Nov 22 2005, 06:40 PM
mr. Wonderful Group: Members Posts: 1,826 Joined: 20-October 04 From: Columbia, California Member No.: 2,978 Region Association: Northern California |
I'm having a lot more trouble with my lights than I thought I would.
First off, PO had the car wired so that the fogs would only turn on with brights. I see no point in that, but that's how it was wired. They had a black wire w/ blue stripe coming out from under the dash wiring harness area plugged into the #3 fuse. I think this black wire with blue stripe was supposed to go onto the fog light switch? There were only 2 wires plugged into the fog light switch when I found it. I tried to do the fog light rewiring that required cutting a few wires, and piggybacking a few. I failed to get that to work. So I bought a fog light flash kit and it's well made. I have it all wired up, and the fog lights were working with the ignition just like they're supposed to and would flash when I pulled the stalk back. My headlights would open up, but the headlights would NOT turn on, but parking lights would. I turned the turn signal lever down to see if the signals would work and I lost my dash lights, and fog lights. I know this has nothing to do with the fog light flasher kit, I'm not flaming on that. It's got to be the PO's wiring. I'm frusterated as hell. (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) First off, what's supposed to go into the #3 fuse closest to the seat? |
lapuwali |
Nov 23 2005, 03:02 PM
Not another one! Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 |
Beware that this is all just about the most complicated section of the wiring system on the 914.
There's a relay on the fuse board that's a square box, usually silver, which is mounted "upside down", with the unwired end attached to the board and the wires pushed on to the terminals. This controls whether the high or low beams are on, and switches between those two states with the high beam switch on the stalk. There's another relay that generates the flashing for the turn signals and the hazard flashers, which is a round three-prong relay (flat blade prongs) that plugs into the fuse board. The rest of the relays on the fuse board are 5 terminal (round terminals) round relays that plug into the board. I hated this section of the stock wiring so much I completely redesigned it for my rewire, but it's not for everyone (no hazards, and you have to use a different high beam switch). |
Lo-Fi Version | Time is now: 26th September 2024 - 05:20 PM |
