Transmission Rebuild Costs?, Don't want to try this myself |
Michael J |
Nov 25 2005, 07:15 PM
Welcome to 2007 Group: Members Posts: 268 Joined: 23-November 04 From: Olympia, WA Member No.: 3,166 |
I have a side shifter in my '72 that works OK except for the typical 2nd gear grind. (IMG:http://www.914world.com/bbs2/html/emoticons/mad.gif) I am tired of having to s-l-o-w-l-y shift into 2nd to avoid the grind. Of course it is worse when it's cold out. So I want to at least fix 2nd. What should I expect to pay for this repair or a more complete rebuild? At a swap meet in Seattle last fall there was a "rebuilt" sideshifter for about $300 if I remember right and there is a "rebuilt" transaxle in our classified section for around $700 + core cost.
While I consider myself mechanical enough I don't want to learn for the first time on my gearbox. Way too many little bitty pieces. (IMG:http://www.914world.com/bbs2/html/emoticons/idea.gif) So I am looking for someone in the Seattle/Olympia area that could help me out. Either do the work or look over my shoulder so it get's done right the first time. I would also consider purchasing a good used stock gearbox. Thanks . |
Brad Roberts |
Nov 26 2005, 12:55 AM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Problem is:
The 915's are worn out also. Huge issue with the pinion bearing races being loose in the 915 alum and mag cases. I started seeing it in the 901/914 tranny also. B |
Lo-Fi Version | Time is now: 26th December 2024 - 05:38 PM |
