jgara962 |
Yo, this is how I roll ![]() ![]() ![]() Group: Members Posts: 823 Joined: 5-April 05 From: Napa, CA Member No.: 3,879 Region Association: Northern California ![]() |
Installing a starter buttong inside the car, but there are three red wires coming out of the ignition connector - which is the hot feed that gets connected to the other spade terminal?
From the wiring diagram 15 - which also has a black wire coming out of the same terminal, both going to the fuse panel 30 - goes back to the starter X - on the diagram it goes to a square with the number 49 in it (I have no idea what that stands for) I already have the yellow wire from the solenoid connected and thought the power would be X, but I think I guessed wrong. Thanks!!! |
lapuwali |
Not another one! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 4,526 Joined: 1-March 04 From: San Mateo, CA Member No.: 1,743 ![]() ![]() |
What you want is to connect the new starter button to the switched power (black wire) out of the ignition switch and connect it to the yellow wire that goes back to the starter. Make sure the button you're using can handle the current required to operate the starter solenoid, which is going to be fairly hefty. Figure about 5A, or about 65W. If you connect to a red (battery+) wire instead of a black wire, you'll be able to use the starter button to turn the engine over with the ignition off. There are a cluster of battery power wires near the fusebox that's a convenient place to tap unswitched power. |
Lo-Fi Version | Time is now: 26th June 2024 - 02:24 AM |
