boxstr |
MEMBER:PACIFIC NORTHWEST REGION ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-December 02 From: OREGON Member No.: 12 Region Association: Pacific Northwest ![]() |
Well here is a new winter project, not really just a few personal things to do to get it ready for the track.
Traded the black 944 for this, a 2004 Birel, ex factory team shifter kart TAG converted, 6 hours on the frame and zero hours on the new 125cc motor. Attached image(s) ![]() |
jhadler |
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 ![]() |
Having driven a shifter kart a number of times, I can tell you they're a blast and half...
A few things: 1) Get a flak jacket. It's a tight fitting rib protector. Trust me, you won't regret it! 2) Shift... A LOT. The faster you grab the gears, the faster you will accelerate. Remeber, it's a two stroke motor, with a power band about 1 inch wide. So keep snatching the gears faster than you think you should, and watch everything blur as you accelerate to warp speed. (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/w00t.gif) 3) If you're going to run it often, be prepared to rebuild the motor at least once a year. It's not hard to do, nor is it really expensive. But the top end will need work often... Less often if it's a stock build, more often if it's a race motor. 4) Did I mention the rib protector? Along those lines, if the seat doesn't fit perfectly, and I do mean PERFECTLY, get a new one that does. Your aching body will thank you. The seat needs to be quite snug. Remember, no harnesses... 5) The most compliant component of the chassis is your spine, so make sure you have a good fitting seat and a good rib protector. It's a punnishing ride, but an absolute hoot and a half when you get that thing scootin'... (IMG:http://www.914world.com/bbs2/html/emoticons/burnout.gif) Have fun! -Josh2 |
Lo-Fi Version | Time is now: 26th June 2024 - 08:34 AM |
