Found leak in fuel line..., Any quick fix? just to check if problem? |
914zim |
Aug 21 2003, 09:04 PM
Still pretty clueless... Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Hi fellas:
I think I may have found out why my car starts, but doesn't stay running (previous post). I noticed a small spot of gas under my 914 and there was a small amount of gas on the right side drainage hose that drains from the hood. After moving the charcoal canister and a few other things out of the way, I lifted the 2 gas lines out of the clip (right side). As I lifted the right line (pressure line?) away from the clip a small stream of gas squirted out! There is a very small pin hole in the line and it looks like something hot touched the line and melted a small area or something was rubbing on it. The hole is in an area that looks worn. Could this be why my car will start, but not stay running? I'm pretty sure this leak is on the pressure side of the circuit. It goes to cylinders 3 and 4 first, then across to 1 and 2. OK, I know everyone will say I need to replace ALL the fuel lines in my car, but I was wondering if there was a way I could maybe splice in a short piece of line, just to see if this is my problem. The section where the leak is can be easily reached. Maybe I could place a small clamp over the hole? What do you all think? Anyone got any ideas? Thanks guys... Andy... |
Qarl |
Aug 21 2003, 10:05 PM
Shriveled member Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None |
Two words...
Duct tape.... Two more words... Just kidding! Or you will have two MORE words Hot fire! and you will need TWO MORE words Fire extinguisher Best bet is to listen to all of our sage advice and just.... Replace lines!!!!!!!! |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:33 PM |
