Found leak in fuel line..., Any quick fix? just to check if problem? |
914zim |
Aug 21 2003, 09:04 PM
Still pretty clueless... Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Hi fellas:
I think I may have found out why my car starts, but doesn't stay running (previous post). I noticed a small spot of gas under my 914 and there was a small amount of gas on the right side drainage hose that drains from the hood. After moving the charcoal canister and a few other things out of the way, I lifted the 2 gas lines out of the clip (right side). As I lifted the right line (pressure line?) away from the clip a small stream of gas squirted out! There is a very small pin hole in the line and it looks like something hot touched the line and melted a small area or something was rubbing on it. The hole is in an area that looks worn. Could this be why my car will start, but not stay running? I'm pretty sure this leak is on the pressure side of the circuit. It goes to cylinders 3 and 4 first, then across to 1 and 2. OK, I know everyone will say I need to replace ALL the fuel lines in my car, but I was wondering if there was a way I could maybe splice in a short piece of line, just to see if this is my problem. The section where the leak is can be easily reached. Maybe I could place a small clamp over the hole? What do you all think? Anyone got any ideas? Thanks guys... Andy... |
tod914 |
Aug 21 2003, 11:14 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
I use high pressure line with a inner diameter of 7mm.
I picked it up at a VW parts store. Maybe $7.00 a meter? Probally 4 meters will be more than enough. Better check the plastic lines that come from the center tunnel into the engine bay too. They get real brittle. The lines under the tank too should be replaced. It is very easy to do. Syphin the tank and its light enough for 1 person to pick up. Good luck and be safe!! |
Lo-Fi Version | Time is now: 24th September 2024 - 12:58 PM |
