Nohair |
Newbie ![]() Group: Members Posts: 10 Joined: 9-October 05 From: Eugene, Oregon Member No.: 4,931 ![]() |
Hello everyone! I think I have read somewhere a way to install 944/944T brakes(rear) on a teener and was wondering if anyone here has any knowledge of this or have I been dreaming again? (IMG:http://www.914world.com/bbs2/html/emoticons/huh.gif)
Am I under the wrong assumption that a 911 front suspension will " bolt in" a 914? I am very much a newbie and in a hurry to learn!!! sorry if these questions are a much talked about already thanks for your time everyone nohair |
Jeroen |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,887 Joined: 24-December 02 From: The Netherlands Member No.: 3 Region Association: Europe ![]() |
you can use 944turbo or 964 front brakes
you need struts with 3.5" brake mounting tabs (911 SC or Carrera 3.2) the mounting holes on the 944turbo calipers are spaced slightly larger than 3.5" idealy, you plug these holes and redrill them to 3.5" but others have also just filed the holes to fit with good results once that's done, they'll bolt up to the struts without adapters or other mods you also need 24mm front brake rotors (911 Carrera 3.2) |
Lo-Fi Version | Time is now: 25th June 2024 - 10:28 PM |
