Found leak in fuel line..., Any quick fix? just to check if problem? |
914zim |
Aug 21 2003, 09:04 PM
Still pretty clueless... Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 |
Hi fellas:
I think I may have found out why my car starts, but doesn't stay running (previous post). I noticed a small spot of gas under my 914 and there was a small amount of gas on the right side drainage hose that drains from the hood. After moving the charcoal canister and a few other things out of the way, I lifted the 2 gas lines out of the clip (right side). As I lifted the right line (pressure line?) away from the clip a small stream of gas squirted out! There is a very small pin hole in the line and it looks like something hot touched the line and melted a small area or something was rubbing on it. The hole is in an area that looks worn. Could this be why my car will start, but not stay running? I'm pretty sure this leak is on the pressure side of the circuit. It goes to cylinders 3 and 4 first, then across to 1 and 2. OK, I know everyone will say I need to replace ALL the fuel lines in my car, but I was wondering if there was a way I could maybe splice in a short piece of line, just to see if this is my problem. The section where the leak is can be easily reached. Maybe I could place a small clamp over the hole? What do you all think? Anyone got any ideas? Thanks guys... Andy... |
rhodyguy |
Aug 22 2003, 06:52 AM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,106 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
take 2 days and do every piece of line, period. my thought is, if one spot is leaking, when that one is fixed the fuel will find the next weakest point. throwing a splice at it just gives you 1 more potential leak. how many times do you intend to pull the tank to address this issue?
kevin |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:30 PM |
