914zim |
Still pretty clueless... ![]() ![]() Group: Members Posts: 221 Joined: 29-July 03 From: New Berlin, WI Member No.: 962 ![]() |
Hi fellas:
I think I may have found out why my car starts, but doesn't stay running (previous post). I noticed a small spot of gas under my 914 and there was a small amount of gas on the right side drainage hose that drains from the hood. After moving the charcoal canister and a few other things out of the way, I lifted the 2 gas lines out of the clip (right side). As I lifted the right line (pressure line?) away from the clip a small stream of gas squirted out! There is a very small pin hole in the line and it looks like something hot touched the line and melted a small area or something was rubbing on it. The hole is in an area that looks worn. Could this be why my car will start, but not stay running? I'm pretty sure this leak is on the pressure side of the circuit. It goes to cylinders 3 and 4 first, then across to 1 and 2. OK, I know everyone will say I need to replace ALL the fuel lines in my car, but I was wondering if there was a way I could maybe splice in a short piece of line, just to see if this is my problem. The section where the leak is can be easily reached. Maybe I could place a small clamp over the hole? What do you all think? Anyone got any ideas? Thanks guys... Andy... |
Lawrence |
Senior Member ![]() ![]() ![]() Group: Benefactors Posts: 1,661 Joined: 5-February 03 Member No.: 244 Region Association: None ![]() ![]() |
Good morning, Andy.
I have to echo the other sentiments. My *assumption* is that you're talking about the black rubber lines, not the hard plastic ones. Replacing all the rubber fuel lines really isn't difficult or expensive. Work one at a time, and while you're in there use real fuel injector hose clamps - not those crappy generic hose clamps. From the bird board... 2.0 FI Diagram -Rusty (IMG:style_emoticons/default/smoke.gif) |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:51 PM |
