T fitting instead of prop. valve, what is the rational? |
DanT |
Dec 1 2005, 08:18 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
Ok, I know this has probably been discussed in many threads before. But, what is the reasoning for replacement of the Prop. valve with the "T" fitting for the rear brakes. Does the prop. valve cause more line pressure to the fronts or the rears when it is operating properly? I want to understand the engineering aspects of this modification.
I will be running "M" calipers with mythical billet hubs in the front and stock 914-4s in the rear. thanks (IMG:http://www.914world.com/bbs2/html/emoticons/unsure.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/wacko.gif) |
J P Stein |
Dec 3 2005, 04:46 PM
Irrelevant old fart Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None |
Basicaly, what Bill, Andys & I are talking about is trail braking
into a corner. With more rear bias the car will tend to oversteer on entry....depending on how deep you like to go....or have to go on a OOOPs (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif). You can have too much of a gud thing as Bill points out. You can either change your driving style (style is not revelant describing mine) or turn the knob... if you have one. |
Lo-Fi Version | Time is now: 25th June 2024 - 10:13 PM |
