Nick |
Member ![]() ![]() Group: Members Posts: 144 Joined: 25-June 04 From: Washington DC Member No.: 2,250 ![]() |
I spent today installing new rear wheel bearings and that went OK I think. I left the swing arm on the car and just unbolted the rear brake calipers, but left all the lines connected. I backed out of the garage and the brake pedal went straight to the floor. Pumping didn't seem to help. I can see no leaks and the brake fluid is full. I lift the car off the ground again and had a helper step on the brakes. all the wheels locked to the point I couldn't turn them by hand. I guess the question is what should I look at next?
Nick |
ClayPerrine |
Life's been good to me so far..... ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 15,591 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille ![]() ![]() |
Two things...
1. check the venting clearance on the rear pads. 2. Bleed the brakes. |
Lo-Fi Version | Time is now: 26th June 2024 - 05:10 AM |
