groot |
Dis member ![]() ![]() ![]() Group: Members Posts: 896 Joined: 17-December 03 From: Michigan Member No.: 1,444 ![]() |
I measured my front and rear motion ratios yesterday and wanted to compare notes with any that have done the same.
For the rear suspension I took ~20 data points and did a best fit analysis to come up with 1.00 to 1.00 damper travel to wheel travel with strong statistical correlation. My front geometry is a bit different than a standard 914, so the motion ratio should be different, too. I measure ~10 points and found 0.83 damper travel to wheel travel, again with strong statistical correlation. I'm about to order my rear shocks and this is one of the bits of data they need to build the shocks. |
Brett W |
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,856 Joined: 17-September 03 From: huntsville, al Member No.: 1,169 Region Association: None ![]() ![]() |
Kevin's right packaging is a big problem with long a-arms. I am having to run pretty short upper and lower arms in the rear to get around the tranny. Up front I could run as long as necessary but found that the 21in length will work fine for my application. With as little wheel travel as I am planning for the camber change is minimal.
Lo-Fi Version | Time is now: 25th June 2024 - 10:18 PM |
