mskala |
R ![]() ![]() ![]() Group: Members Posts: 1,925 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None ![]() ![]() |
Maybe somebody can educate me on how the clutch is supposed
to be. While driving today, I felt something give when I pressed the clutch pedal, then it was still pulling (cable not broken) but didn't have the pedal travel to release all the way. Limp home, check back of cable, still fine not frayed. Check front of cable, not frayed. Higher free play than it was. Looked at front of tube while pressing pedal (tough to do!), tube not broken, also firewall tube not broken. When cable totally removed (looks good still), the release fork can be moved about 1 inch without any resistance. Can't see enough inside to tell anything. Should the release fork be movable (much)? Do I have to pull the trans to find out what's wrong? Thanks all. |
mskala |
Well, didn't see any problems with the pedal roll pin and from the light
I could get in there, no loss of the release fork bushing. Then I took the whole cable out, and where the metal sleeve ends at the firewall, cable is frayed bad. That end is sharp, but of course isn't supposed to be contacting the cable. I don't know how I did that, but unless I see something else, I'm going to get a new cable in and see. Thanks |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:48 PM |
