dmilzoff |
Member ![]() ![]() Group: Members Posts: 67 Joined: 2-March 03 From: Ossining, NY Member No.: 377 ![]() |
Am I getting too fanatical or is this a real problem?
On my 914-6, I have 911 brakes up front and original rear brakes. I found the right rear brake dragging (smoking!). After opeining the vent clearance and oiling the emergency brake linkage, I took the car out for a 4 mile ride. Rotor temperatures using a infrared temp probe was Left Front 145 deg. F. Right Front 150 Left Rear 180 Right Rear 225 Question 1: Shouldn't the front rotors be hotter? Should I remove the brake proportioning valve or replace it with a new one to correct this? Question 2: Is the right rear too hot for such a short ride? |
Brad Roberts |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None ![]() |
A balanced brake system will only have about a 15-20 degree spread between the front and rear (fronts hotter).
I'm going to guess your rear calipers are sticking (pistons sticking in the bore). It could be the prop valve but both sides would show equal temps if the prop valve was crap. Kevin is dead on with the brake line thoughts... I'm glad to see somebody actually using their infrared temp gun... You should see the brake temps from a factory GT3RS (400-500 degree range) B |
Lo-Fi Version | Time is now: 24th June 2024 - 07:43 AM |
