Rotor Temperatures, Am I getting too fanatical? |
dmilzoff |
Aug 23 2003, 01:31 PM
Member Group: Members Posts: 67 Joined: 2-March 03 From: Ossining, NY Member No.: 377 |
Am I getting too fanatical or is this a real problem?
On my 914-6, I have 911 brakes up front and original rear brakes. I found the right rear brake dragging (smoking!). After opeining the vent clearance and oiling the emergency brake linkage, I took the car out for a 4 mile ride. Rotor temperatures using a infrared temp probe was Left Front 145 deg. F. Right Front 150 Left Rear 180 Right Rear 225 Question 1: Shouldn't the front rotors be hotter? Should I remove the brake proportioning valve or replace it with a new one to correct this? Question 2: Is the right rear too hot for such a short ride? |
Brad Roberts |
Aug 23 2003, 03:51 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
I'm betting you have one piston hanging up on each rear caliper.
Honestly.. replacing those rear brake lines with the engine in the car is more of a pain than rebuilding the rear calipers. Getting to the top bolt on the prop valve with the engine in the car is also a chore... B |
Lo-Fi Version | Time is now: 25th September 2024 - 11:04 PM |
