> Custom front sway bar???, Coleman racing
Andyrew
post Dec 10 2005, 10:25 PM
Spooling.... Please wait
I really wouldnt mind putting a bigger front sway bar on my car, but since im plowing from understeer around town, im not really worrying about it..
BUT I am not rather liking the 350 or 500 I'd have to spend to get a good bar on my car.
I currently have a stock bar up front, and 22mm T bars (ya, thats my kicker up front...)
I was thinking that one of these coleman bars would work..
(IMG:http://www.colemanracing.com/catalog/images/pn658.jpg)
They have the bar thickness from 3/4in to 1 1/2 in...
Bar is 37.5 in long...
Could it work?
I know there will be fabrication involved (im cool with that.. only means more fun..)
http://www.colemanracing.com/catalog/index...&sort=2a&page=1
Also, they have Just the bars at different lengths. But only at 1 1/4 thickness. Lengths from 32" to 43" and .125, .188, and .25 wall (whatever that means)
Bars by themselves for 110 bucks.
Any thoughts??
groot
post Dec 13 2005, 10:34 AM
Dis member
QUOTE (Andyrew @ Dec 13 2005, 07:25 AM)
At entry. I will just understeer if I try to take a general corner. I would need to start the corner wide, and grab the throttle early so that I can plant the rear end, and get the front to stick.
Good info, Andrew....
Turn-in understeer. I'm assuming that a judicious amount of throttle is required, but not too much, right? Have you tried trailing braking to get it to turn? That can keep more load on the front tires and that will help you turn.
More front bar will hurt this condition. Try disconnecting the stock bar for one fun run and see how it goes. If that doesn't help you've got other issues at work.
Andyrew   Custom front sway bar???   Dec 10 2005, 10:25 PM
Aaron Cox   check out slugmika's blog. he has a custom swa...   Dec 10 2005, 10:33 PM
Dan (Almaden Valley)   Putting a bigger bar up front is not going to help...   Dec 10 2005, 10:39 PM
Mueller     Dec 10 2005, 10:41 PM
Andyrew   I saw his bar as well. I sent him a message, mayb...   Dec 10 2005, 10:43 PM
Andyrew   As per my problem of understeer, Yes, I know. But...   Dec 10 2005, 10:45 PM
Dan (Almaden Valley)   Stock bar is right at 40 inches in length.   Dec 10 2005, 10:48 PM
Andyrew   Thanks dan! That gives me one step closer.   Dec 10 2005, 10:50 PM
Aaron Cox   PM sent   Dec 10 2005, 10:51 PM
Andyrew   PM recieved... http://www.914...   Dec 10 2005, 11:04 PM
dlo914   <...   Dec 11 2005, 01:34 AM
Andyrew   Already dibbed out... lol Gona be traded for a f...   Dec 11 2005, 01:41 AM
dlo914   <...   Dec 11 2005, 01:44 AM
groot   I've used this type of bar for my car. I got t...   Dec 11 2005, 11:16 AM
jd74914   I wish they made the bars with square end mounts i...   Dec 11 2005, 11:40 AM
Brett W   This style of bar is really common on race cars. ...   Dec 11 2005, 11:51 AM
Andyrew   Groot, would you mind sending some pics if you hav...   Dec 11 2005, 12:20 PM
Brett W   my setup will use bars less than 20inches long so ...   Dec 11 2005, 12:32 PM
Andyrew   Nope, and im asking santa for a Miller (or a linco...   Dec 11 2005, 12:40 PM
groot   Here's a pic... pretty dirty and partially dia...   Dec 11 2005, 02:12 PM
Andyrew   What was the length of the sway bar you used? Wha...   Dec 11 2005, 03:11 PM
Brett W   You will only make your car worse if you got to a ...   Dec 11 2005, 03:50 PM
Brett W   something just occured to me. When I was running ...   Dec 11 2005, 04:14 PM
jd74914   <...   Dec 11 2005, 04:46 PM
Brett W   if you lower your car with the a-arms parallel to ...   Dec 11 2005, 05:28 PM
Mueller   <...   Dec 11 2005, 08:30 PM
jd74914   <...   Dec 11 2005, 08:36 PM
Aaron Cox   <...   Dec 11 2005, 09:11 PM
Andyrew   Car will be dedicated autox and track car. With a ...   Dec 12 2005, 01:31 AM
Brett W   You really should run more rear spring. Then you ...   Dec 12 2005, 08:24 AM
Andyrew   Cool stuff. I have Engman long kit in a box, and ...   Dec 12 2005, 08:54 AM
groot   I use a standard length 37.5" bar. It's 7/8" d...   Dec 12 2005, 01:08 PM
Andyrew   I definately need more front tire... My tires are...   Dec 12 2005, 03:10 PM
groot   Those pieces will make a nice adjustable stabilize...   Dec 12 2005, 03:55 PM
Brett W   Andrew, try this first. Stock front bar Camber, a...   Dec 12 2005, 04:06 PM
andys   I have to agree with Kevin and Brett. I think you ...   Dec 12 2005, 06:01 PM
Andyrew   I know my setup is way off. I gave myself a baseli...   Dec 12 2005, 06:19 PM
Andyrew   Heres a pic of the configuration at the wcc. I t...   Dec 12 2005, 06:20 PM
Brett W   Listen if the car is pushing in your current setup...   Dec 12 2005, 08:30 PM
groot   Dude, Have it your way, we're just trying to ...   Dec 13 2005, 08:44 AM
Andyrew
  Dec 13 2005, 09:25 AM
d914   not a techie guru, but the cars do turn better und...   Dec 13 2005, 09:44 AM
groot   <...   Dec 13 2005, 10:34 AM
Andyrew   Trailing arm braking, and engine braking generally...   Dec 13 2005, 12:33 PM
- Lo-Fi Version Time is now: 18th June 2024 - 07:34 AM
