Andyrew |
Spooling.... Please wait ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,376 Joined: 20-January 03 From: Riverbank, Ca Member No.: 172 Region Association: Northern California ![]() ![]() |
Well we went to Harbor Freight and got some stuff today! One of them being a new Mig welder..
(IMG:http://members.rennlist.com/dan10101/Welding101-%20005.jpg) So being that I have been working on preping the rusty battery tray for surgery, we (me and dad) decided that It was a good Idea to practice.. So we got out the old doors from the cut up 73, and had a hay day! I did cut out a pannel from one of the doors to use for sheet metal for the surgery of the battery tray area.. So we take the welder out of the box, and have a little trouble with the simple instructions (oh well) and I spend 15 mins putting on the handle to the "screen" which I though was a piece of junk till I used it.. (you can see me using it in some of the pics) (IMG:http://members.rennlist.com/dan10101/Welding101-%20022.jpg) We also got out our age old arc welder, which I used before and I got semi familiar with it last time and made some good welds.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20004.jpg) So we got out the mig and tried it out, First impression, Piece of junk. I thought there was no way this thing would ever weld as good as the arc, all it did was make little bubbles!! (IMG:style_emoticons/default/headbang.gif) (IMG:http://members.rennlist.com/dan10101/Welding101-%20002.jpg) So I make a few holes, and hey, my weld held, kinda.. So as the day progressed, and I watched Dad (who wasnt doing any better than me with the mig) I noticed some things, practiced a little, tried to fill in some holes, ect.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20044.jpg) I think I can do this now, and the mig actually will be able to suit my needs quite well, I had no problem filling in a 1 in hole.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20033.jpg) After my dad did some reading on a body repair sight, he said some things that where mentioned on the sight and that was the turning point from bad, to good.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20042.jpg) As you can see from the pics, I went from little bubbles to a solid uniform line, with solid connection on both sides.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20043.jpg) And as you can see the welds hold.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20046.jpg) Im happy, and I think I will be able to fix this rust area. Not bad for a days play! (IMG:style_emoticons/default/wink.gif) Andrew |
dan10101 |
TORQUE-o-holic ![]() ![]() ![]() Group: Members Posts: 1,140 Joined: 29-April 03 From: Eagle Point, Or Member No.: 626 Region Association: Pacific Northwest ![]() |
We appreciate everyones suggestions. However, we're stuck with this one for a while. It cost about the same as renting a good mig for the weekend, and from what I can see so far, it will get the job done.
We did have some fun yesterday. Found out the Arc welder can do a good impersination of a cutting torch, might come in handy someday. Anyone need a battery box welded to the outside of their door? We work cheap! That was probably the best weld of the day. Rusted old battery tray to the support beams in the door. Solid as a rock, probably have to cut it off of there to be able to throw it away. Thanks for the welding tips. I'd love to hear more... Surface prep, technique, grinding tips, finish prep. Here is a close up of a good weld. Any further critique/suggestions? Lastly, yes we get the point, gas is good... Attached image(s) ![]() |
Lo-Fi Version | Time is now: 24th June 2024 - 07:28 AM |
