New welder, Cheapo Mig.., The reason why practice makes "perfect" |
Andyrew |
Aug 24 2003, 01:13 AM
Well we went to Harbor Freight and got some stuff today! One of them being a new Mig welder..
(IMG:http://members.rennlist.com/dan10101/Welding101-%20005.jpg) So being that I have been working on preping the rusty battery tray for surgery, we (me and dad) decided that It was a good Idea to practice.. So we got out the old doors from the cut up 73, and had a hay day! I did cut out a pannel from one of the doors to use for sheet metal for the surgery of the battery tray area.. So we take the welder out of the box, and have a little trouble with the simple instructions (oh well) and I spend 15 mins putting on the handle to the "screen" which I though was a piece of junk till I used it.. (you can see me using it in some of the pics) (IMG:http://members.rennlist.com/dan10101/Welding101-%20022.jpg) We also got out our age old arc welder, which I used before and I got semi familiar with it last time and made some good welds.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20004.jpg) So we got out the mig and tried it out, First impression, Piece of junk. I thought there was no way this thing would ever weld as good as the arc, all it did was make little bubbles!! (IMG:style_emoticons/default/headbang.gif) (IMG:http://members.rennlist.com/dan10101/Welding101-%20002.jpg) So I make a few holes, and hey, my weld held, kinda.. So as the day progressed, and I watched Dad (who wasnt doing any better than me with the mig) I noticed some things, practiced a little, tried to fill in some holes, ect.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20044.jpg) I think I can do this now, and the mig actually will be able to suit my needs quite well, I had no problem filling in a 1 in hole.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20033.jpg) After my dad did some reading on a body repair sight, he said some things that where mentioned on the sight and that was the turning point from bad, to good.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20042.jpg) As you can see from the pics, I went from little bubbles to a solid uniform line, with solid connection on both sides.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20043.jpg) And as you can see the welds hold.. (IMG:http://members.rennlist.com/dan10101/Welding101-%20046.jpg) Im happy, and I think I will be able to fix this rust area. Not bad for a days play! (IMG:style_emoticons/default/wink.gif) Andrew |
airsix |
Aug 24 2003, 11:04 AM
I have bees in my epiglotis Group: Members Posts: 2,196 Joined: 7-February 03 From: Kennewick Man (E. WA State) Member No.: 266 |
Can't tell from the pictures how much surface prep you did, but paint looks like it runs right up to the welds. Did you grind back the area to be welded so you were on clean bare metal? Roughing it up with a sander or wire wheel so you can see a little bare medal doesn't cut it. You want nice shiny bare metal with all the paint/oil/etc removed. You'll be amazed at the difference. If the surface has been exposed to grease or oil use a solvent to clean it first.
-Ben M. |
Lo-Fi Version | Time is now: 22nd June 2024 - 08:31 PM |
