Lou W |
"Here Kitty Kitty" my ass...... ![]() ![]() ![]() ![]() Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain ![]() |
I have a Speedaire Air Compressor, I just replaced the cylinder head due to the valves were bad.
Now, when I turn the compressor on, the pressure goes up to 140lbs, once its reaches 140lbs, the compressor automatically shuts off. The Bleed Off Valve then bleeds off down to 95lbs which then turns the compressor automatically on returning it up to the 140lbs. If I turn the compressor switch off at the 140lbs, the Bleed Off Valves bleeds the pressure down to 120lbs and stops there. My understanding is that the compressor should shut off at 125lbs, then once the pressure drops to 95lbs, it would kick back on. The only thing that should cause the pressure to drop from the 125lbs is when it is being drawn down by use of air tools not the Bleed Off Valve. Any Suggestions? Attached image(s) ![]() |
914GT |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,100 Joined: 11-October 04 From: Tucson Member No.: 2,923 Region Association: Southwest Region ![]() |
You need a new pressure switch if the tank safety relief valve is opening. It should not go over about 125 psi
Lo-Fi Version | Time is now: 28th June 2024 - 01:11 AM |
