OT-Air Compressor Problems, Please help me, my car is waiting |
Lou W |
Dec 14 2005, 12:30 AM
"Here Kitty Kitty" my ass...... Group: Members Posts: 4,109 Joined: 9-May 04 From: Roseburg, OR. Member No.: 2,039 Region Association: Spain |
I have a Speedaire Air Compressor, I just replaced the cylinder head due to the valves were bad.
Now, when I turn the compressor on, the pressure goes up to 140lbs, once its reaches 140lbs, the compressor automatically shuts off. The Bleed Off Valve then bleeds off down to 95lbs which then turns the compressor automatically on returning it up to the 140lbs. If I turn the compressor switch off at the 140lbs, the Bleed Off Valves bleeds the pressure down to 120lbs and stops there. My understanding is that the compressor should shut off at 125lbs, then once the pressure drops to 95lbs, it would kick back on. The only thing that should cause the pressure to drop from the 125lbs is when it is being drawn down by use of air tools not the Bleed Off Valve. Any Suggestions? Attached image(s) |
Dead Air |
Dec 14 2005, 07:09 PM
Senior Member Group: Members Posts: 1,268 Joined: 9-May 04 From: Buffalo, NY Member No.: 2,042 |
I'd pull it apart and make sure everything is clean, the points and such...
Hi Joe (permagrin) I think that's great... "perma-grin" or maybe i'm just too high! (IMG:http://www.914world.com/bbs2/html/emoticons/wavey.gif) Where does "compressor oil" go? |
Lo-Fi Version | Time is now: 28th September 2024 - 09:09 AM |
