Qarl |
Shriveled member ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 5,233 Joined: 8-February 03 From: Florida Member No.: 271 Region Association: None ![]() ![]() |
Okay... I spent the weekend disassembly the rear suspension.
Oh yeah, my suspension was all off the car. F-ING CASTELATED NUTS!!!!! It took quite a few sessions with a propane torch and a high-torque impact wrench on max setting to remove each one. It's real fun removing this nut without the car mounted to anything. The hub and axle just rotate away!!! I ended up placing the hub (still mounted on the trailing arm with the axle attached into a vise on my bench). I tried removing it with a socket extension and 24" breaker bar. No such luck. The heat and impact wrench worked after many repeated attempts. My teeth are sore from clamping down. Okay.. so now I just have to remove the hub and bearings. No problem. What about the bushings? I plan on installing Muellers needle bearings in the rear, but I have no idea how to get the old stuff out. Any advice? |
URY914 |
I built the lightest 914 in the history of mankind. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 126,249 Joined: 3-February 03 From: Jacksonville, FL Member No.: 222 Region Association: None ![]() |
Invite Jenna Jamison over...
Lo-Fi Version | Time is now: 29th April 2025 - 06:09 PM |
